CBS350 routing issue
informatiqueVDL
Hi everyone,
I'm trying to set up a little lab with 2 CBS350.
I want to link those 2 CBS by connecting te2 with L3 (no switch port. IP 172.31.254.253/30 and 172.31.254.254/30)
On CBS-A I have VLAN 92 IP 172.16.14.1/24 and PC IP 172.16.14.10/24 (with GW IP VLAN92).
On CBS-B I have VLAN 93 IP 172.16.15.1/24 and PC IP 172.16.15.10/24 (with GW IP VLAN93)
IP Routing is on. Routes on CBS are:
172.16.14.0/24 via 172.31.254.254
172.16.15.0/24 via 172.31.254.253
From every PC I can ping their own GW, the IP of each te2, but can't ping each other or opposite VLAN IP.
Is it due to something I forgot to set up, or is it due to CBS limitations ?
Best regards.
Thanks for your answers.
I just realized that the ping only works when a device is connected on a gi port.
Ping on vlan's IP is not working if there is no device on the vlan !
So it seems it's working, I can ping devices and vlan'IP from both CBS.
Thank you for the help !
10 Replies 10
amikat
Can you please share the configuration of one CBS350 box.
Thanks & Regards,
Antonin
Sure.
sh run
config-file-header
CBS350-CLSH-BL
v3.4.0.17 / RCBS3.4_950_377_325
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0...
unit-type-control-start
unit-type unit 1 network gi&tw-2 uplink te
unit-type-control-end
spanning-tree mode rapid-pvst
spanning-tree loopback-guard
vlan database
vlan 93,131,151
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
bonjour interface range vlan 1
hostname CBS350-CLSH-BL
username a... privilege 15
interface vlan 93
ip address 172.16.15.1 255.255.255.0
interface vlan 131
ip address 10.14.103.1 255.255.255.0
interface vlan 151
ip address 192.164.100.1 255.255.255.0
interface GigabitEthernet1
spanning-tree portfast
switchport access vlan 151
interface GigabitEthernet2
interface GigabitEthernet3
interface GigabitEthernet4
switchport access vlan 93
interface GigabitEthernet5
interface GigabitEthernet6
switchport access vlan 131
interface TenGigabitEthernet2
ip address 172.31.254.254 255.255.255.252
no switchport
exit
ip route 10.13.0.0 /16 172.31.254.253
ip route 172.16.14.0 /24 172.31.254.253
ip route 192.163.0.0 /16 172.31.254.253
On the other switch I have VLAN 92, 130 and 150, IP corresponding to the routes.
Is this what you really intended
or did you perhaps intend
ip route 192.168.0.0 /16 172.31.254.253
Rick
Hi Richard.
No it's 192.163.0.0 because my vlan150 ip is 192.163.150.1
Thanks for the information supplied. I understand that you are able to ping from PC this side to 172.31.254.253 and not to int Vlan92, 130, 150 IP addresses. If so can you ping from this CBS box to the Int Vlan opposite addresses?
Best regards,
Antonin
Further to my previous reply I would like to suggest that your static routes configuration should perhaps read as:
ip route 10.13.103.0 /24 172.31.254.253
ip route 192.163.100.0 /24 172.31.254.253
Best regards,
Antonin
Thanks for the update. Glad that you figured out the issue.
Rick
Everything seems ok but I can't see you had enabled "IP routing" command on the switch. By default, it is in Layer 2 mode.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak Kumar,
Yes it's active. It only shows in the sh run when it's not.
