CBS350 Stacking Problem (CBS350-8t-e-2g)
Lucasptt
Hi all,
I'm trying to configure two CBS350-8t-e-2g, everything went fine exept when I wanted to stack them.
I have no "Stack Management" in the "Adminstration" section (WEB configuration).
So I tried in CLI, but the device prompt "Unknow command".
Thoses devices should be stackable, so I don't know what to do.
I also tried to update the Firmware but nothing changed.
Does someone ever had the same issue ? If yes how can I fix it ?
(I'm not an experimenced user)
Thank you !
Best Regards
Lucas
Lucasptt
Yes indeed, I don't see my model in the datasheet.
So no stacking on thoses devices I guess.
In all cases, thank you for your fast answer !
