CCNP issue Sergei Mavashev
smavashev
I'm trying to connect 2 2950's switches to a 3550 switch. Configs are as follows
2950 switch #1
config t
int range fa 0/2 - 12
switchport access vlan 100
exit
int range fa 0/13 - 26
switchport access vlan 200
int range fa 0/1
switchport trunk allow all vlans
2950 switch #2
config t
exit
int range fa 0/1
3550 switch #1
config t
int range fa 0/1 - 2
switchport trunk encapsualtion dot1q
switchport trunk allowed vlan all
int vlan 100
ip address 192.168.1.100 255.255.255.0
int vlan 200
ip address 192.168.1.200 255.255.255.0
ip routing
Issue: The switch 3550 does not show any output when show ip route command is issued. What is the problem ? I tried checking vlan assignments on both 2950 switches, the CDP neighbors work from 3550 it can see both switches via trunks, however I can get the vlans to Ip route between each other what is the issue ? I've also check the version of 3550 router it is 12.1 SMI version. I hope it is not the version I need to do this for my switch CCNP exam. Please let me know or you can even call me at 973 9326300. or email on here. thanks.
On the 3550, you alos need to creat layer-2 vlans
vlan 100
name test
vlan 200
name test1
Then do a sh ip int bri vlan 100 and 200
Reza Sharifi
On the 3550, do you see the interface vlan 100 and 200 in up and up mode?
"sh ip int bri vlan 100"
how about the physical interface?
Ok, the show ip int brief vlan 100 and 200 both show it's in down down state, the physical interfaces 1 and 2 connecting to trunks are in up and up state, I tried doing
int vlan 100
no shut
int vlan 200
no shut
still in down down state, respond...
vlan 100
name test
vlan 200
name test1
Thanks a lot ! It worked !
I greatly appreciate it.
