CE500
Rafael Jimenez
Level 7
Level 7
I have a client that want put the address 10.x.x.x in the vlan1 in a ce500.
How can I avoid this restriction in the ce500.
spremkumar
Level 11
Level 11
hi
you want to access the switch using the ip address defined by the client, if this is the case then you need to make sure that you are logged onto the switch via the default ip address based on your switch model.
http://www.cisco.com/en/US/products/ps6545/products_configuration_example09186a00806da6c9.shtml
above link helps out in getting logged and configuring the same..
regds
