Ce520 - voice vlan problem with smart port
*note ; C520 is all webgui ( no CLI here )
I have reset the configuration of the c520.
After the configuration the vlan 100 was still there.
I configure a vlan 2 name = Cisco-Voice
I want to configure my ports for voice and default vlan access. I have 2 vlan ( 1 = data , 2 = voice ).
now If I use the smart ports wizzard and Choose the 'ip phone + desktop '  It choose vlan 1 for data and vlan 100 for voice.
I can use the drop down menu to change vlan 1 but I can't change the voice vlan, that is my big problem.
At this point, my desktop work but not my phone.
Anyone can help me on that ?
Arthur Kant
The CE520 can be configured using the "web" cli. Going this route may help you to your end goal. http://ipaddress/exec
It was the only switch that I had this problem, other where fine.
I saw some people having the same issue on the net.  If you guys have that problem.
Download a copy of a working config, with a tftp server upload it to the startup config on your switch that have the problem.
it save a lot of time
