Certification. Where to start ? CCENT or CCT ?
Limbov
Hi all,
Which and why should I choose CCENT or CCT ? Which would prepare me better for CCNA?
Any recommendation where to study?
5 Replies 5
luis_cordova
Hi @Limbov
If you plan to pass the CCENT exam (ICND1) and the ICND-2 exam before February 24, then CCENT is a good option.
Otherwise, CCT exam is a better option.
Why?
The CCENT exam will not remain after February 24.
On the other hand, the CCT exam will remain.
Martin L
it is short time left to do CCNET; I would start with CCNA; you can start prepping for CCNA using current books; then update your studies with new topics
CCENT exam will expire on Feb23rd so it sort of no point of taking it unless you can pass both current versions of ICND1 and 2 before Feb 24th
Right to CCNA? Shouldn't I start with CCT to get some basics?
Hi.
I just found that there is 3 different CCT courses. 300£  each of them... Do I need all of them or just one? And if one then which?
CCT Routing & Switching
CCT Data Center
CCT TelePresence
Hi @Limbov
If you want to continue with the CCNA line, I suggest you take the Routing and Switching course.
https://www.cisco.com/c/en/us/training-events/training-certifications/certifications/entry/technician-cct/routing-switching.html
