Configure Access layer switches switches using Packet Tracer
JoshBar75473
luis_cordova
Hi @JoshBar75473
What is your doubt?
-For the first point you will use a mask /24.
-If you must configure HSRP, then the IP gateway must be the virtual gateway.
-For the management network, you can configure vlan interfaces on the switches and assign them an IP within the 10.x.x.x/24 network
luis_cordova
Hi @JoshBar75473
What is your doubt?
