Chain or Ring topology: what is the main advantage of each topology?
I have four SG350X Switch and I plan to stack them.
I have seen that I can operate them under a Chain or Ring topology: what is the main advantage of each topology?
He seems that, compared to ring, chain topology is not considered to be very robust, if so, what are the advantages of Chain?
Giuseppe Larosa
there is no redundancy in the chain topology, the ring topology can support one inter switch link failure.
So I would recommend the ring topology that is actually similar to the way stacks are interconnected in IOS switches starting from C3750 switches and later models.
See the following document
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-350x-series-stackable-managed-switches/smb5237-chain-and-ring-topologies-on-the-sg550xg-and-sg350xg-switche.html#Stacking_Topologies_Overview
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
Joseph W. Doherty
I assume you're going to logical stack the four switches (i.e.) so they will operate as one logical device.
With a chain topology, you need one less inter-switch link. However, that "benefit" I believe is outweighed by redundancy (as also noted by Giuseppe) provided by a ring topology. (The ring topology may also provide more bandwidth between switches [as traffic can travel using either ring path] and might also reduce inter-switch transit latency [assuming the switch chooses the ring path with less hops].)
Hi Giuseppe and Joseph
Thank a lot for clarification.
