Change severity level of storm control messages
as00001111
Hey all,
I configured storm control on my interfaces of a cisco 3850 switch and was wondering if I can change the severity of the log messages when a storm is detected.
The current message is:
%STORM_CONTROL-3-SHUTDOWN: A packet storm was detected on Gi1/0/1. The interface has been disabled.
Level is 3 (Error).
Can I change that to level 2 (Critical) ?
Thank you!
as00001111
any hints?
anyone?
I dont think thats possible to change the alert leve its part of the feature itself l , i dont see it in any storm control config guides , you can only change the rate of messages
weven 6500 which usually has more options than lower end switches deosnt show anything like that
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/storm.html#55541
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
