Change SSH Key on 2960 Switches
CartoGraph
I am trying to change the key for SSH from 1024 to 2048 but I have (so far) no solution for that.
Unfortunately, ip ssh rsa keypair-name SSH and crypto key generate rsa general-keys modulus 2048 label SSH don't work.
I trying also other combinations...
- crypto key generate rsa
- crypto key generate rsa general-keys modulus 2048
- crypto key generate rsa general-keys label SSH modulus 2048
None of the above worked...and the SSH key remains 1024.
Does anyone know how to change the SSH Key for this switch from 1024 to 2048?
Version is Version 12.2(50)SE4.
Thank You!
have you zeroized the existing key first ?
crypto key zeroize rsa
7 Replies 7
Hello and thanks for your reply.
I didn't try yet.
Is there any risk to lose the connection with the switch ?
If you give a label to the key-pair, you have to assign it to your ssh-config:
https://supportforums.cisco.com/t5/security-documents/guide-to-better-ssh-security/ta-p/3133344
Edit: Just see that you did ... Have you first generated the key and then assigned it to the ssh-config?
Yes, I generated the key first.
There is no possibly to assign the key (labeled) to the SSH.
PTNS03(config)#ip ssh ?
  authentication-retries  Specify number of authentication retries
  dscp                    IP DSCP value for SSH traffic
  logging                 Configure logging for SSH
  precedence              IP Precedence value for SSH traffic
  source-interface        Specify interface for source address in SSH connections
  time-out                Specify SSH time-out interval
  version                 Specify protocol version supported
do you need more than 1 key ? Unless you do, zeroize everything and create a new key without the label.
Is there any risk to lose the connection with the switch?
What are the risks if I lose the connection between the zeroize and key generation?
if this is a remote site, use the 'reload in' command before making any changes. If you lose connectivity, the switch will reload by itself with the working configuration (obviously make sure you save the working config to the startup config first).
