Problems with CISCO-CONFIG-COPY MIB and SCP/SFTP over IPv6
oysteingyland
I'm using the CISCO-CONFIG-COPY MIB to upload startup-config from a switch using SCP.
I'm experiencing the same problems on multiple switches / IOS versions:
WS-C3560CG-8PC-S  running 15.0(2)SE
WS-C3560CG-8PC-S running 12.2(55r)EX11
WS-2960-8-TC-L running 12.2.58.SE1
WS-2960-8-TC-L running 15.0.2.SE
I'm successfully using these OID's to upload startup-config to 192.168.202.90 using SCP as transfer protocol:
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.14.1370 i 5
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.3.1370 i 3
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.4.1370 i 1
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.5.1370 a 192.168.202.90
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.6.1370 s config-dump
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.7.1370 s username
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.8.1370 s  password
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.2.1370 i 4
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.14.1370 i 1
Now, as 1.3.6.1.4.1.9.9.96.1.1.1.1.5 (ccCopyServerAddress) is deprecated, I've replaced
ccCopyServerAddress with 1.3.6.1.4.1.9.9.96.1.1.1.1.15.1370 (ccCopyServerAddressType) and 1.3.6.1.4.1.9.9.96.1.1.1.1.16.1370 (ccCopyServerAddressRev1).
As far as I've understood, this be the correct usage for uploading startup-config from the switch with SCP.
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.15.1370 i 1
snmpset -v2c -c <community> <switch> 1.3.6.1.4.1.9.9.96.1.1.1.1.16.1370 s 192.168.202.90
Using the aforementioned OID's, the switch will silently discard the SNMP commands, there is no attempt to initiate a connection with the SCP server whatsoever.
"debug ip scp" prints out these two lines
Dec  5 09:44:33: SSH CLIENT: attempt to create connection failed
Dec  5 09:44:33: SCP: SSH Client connect failed
Now, If I use TFTP as transfer protocol by assigning 1.3.6.1.4.1.9.9.96.1.1.1.1.2 (ConfigCopyProtocol) to 1, it works as expected. If I try to use SFTP,
by assigning ConfigCopyProtocol to 5, the switch will respond with "wrongValue (The set value is illegal or unsupported in some way)".
What I'm really trying to achieve is to use SCP with IPv6, thus must I use ccCopyServerAddressType and
ccCopyServerAddressRev1 instead of ccCopyServerAddress, as the latter OID is a IPv4 type object.
By the way, TFTP/FTP/RCP upload using IPv6 appears to work (atleast I can see a WRQ/SYN-packet to the correct address when I capture the network traffic).
I'll be grateful for any leads or hints.
-Øystein
oysteingyland
In case someone else is experiencing the same problem - this bug is now filed as CSCue43400
This bug has not been fixed.
it still exists in 15.0(2)SE8
hi this is bhaskar,
1.3.6.1.4.1.9.9.96.1.1.1.1.2.1370 this snmp oid working fine for 2950 cisco switch.(ios version 12.1)
1.3.6.1.4.1.9.9.96.1.1.1.1.2.1370  this snmp oid doesnot works in sg300 cisco switch(ios version 1.3.0.1)
need to device config backup with using snmp mib oid (cisco copy-config -mib)
please tell me snmp mib oid for  backup config in cisco SG300 switch
