Changing Cisco Switch
majdalani
Level 3
Level 3
i want to change the telnet password for cisco switches 2950 & 2970, what is the command please ?
3 Accepted Solutions
royalblues
Level 11
Level 11
line vty 0 4
password
wr mem
Narayan
It just the number of terminal lines that are supported on the platform.
All new devices have 16 TTY ports while the old ones just had 5
Narayan
If you use line vty 0 15, the configs will be applied to all the vty ports
under global configuration use the command
"service password-encryption"
This will encrypt the password
Narayan
15 Replies 15
royalblues
Level 11
Level 11
line vty 0 4
password
wr mem
Narayan
Hi Thanks,
whats the difference between :
line vty 0 4
and
line vty 0 15 ??
Narayan
Hi Narayan,
so if i used any it wont be any difference !
The configurations will be applied to only those ports mentioned in the command
eg. if you have 16 vty lines and you configure
line vty 0 4
password
then the password wont be applied to the lines 5 to 15
Narayan
Hi thanks for your quick replies.
does this mean users will still be able to telnet the switch thru these lines ?
Yes..
It is always a best practice to apply these configurations on all the TTY ports
Narayan
WOW !!
u mean i will have to go :
line vty 0 1
line vty 0 2
line vty 0 16
2nd question please, i have applied : live vty 0 15
when i run the show run command, i can see the telnet password, how can i encrypt it , so that the person setting next to me does it read it in plain english ?
Narayan
will this encrypt the enable password as well ?
Yes it will, but you are probably already using an enable secret, which is already encrypted as standard, and much more securely.
Password encryption is pretty weak - there are loads of tools on the Internet to crack them in no time at all. If there is any possibility that someone gets hold of your config listings, you are better off defining a "secret" for each user rather than a "password". (Or even using an authentication server, but that will start getting more complicated and expensive.)
Encrypted passwords are tagged with a '7' in the config listing, and are weak. Secrets are tagged with a '5' and are quite a lot stronger.
Kevin Dorrell
Luxembourg
hi,
this is now my configuration :
line con 0
line vty 0 4
password mypass
login
line vty 5 15
password mypass
login
as u can see there are 2 lines line vty .
my boss configured the switches, when i asked him what did u insert as a commands, he told me as follows :
line vty o 15
login
password mypass
exit
enable secret mypass
what is the first password for and what is the second password for ?
THe first password is the telnet or the user level password and the second one is the privilege password
Narayan
my boss is entering : line vty 0 15 for the telnet command , why then in the show run , it is showing line vty 0 4 ?
