Changing Interfaces on existing Port-Channel
Laurent Soria
Hi all,
I have a core switch and a router which are connected over 4 physical links. These are configured as Port-channel.
- Switch: Cisco C6807-XL
- Router: Cisco WS-C6504-E
My task is now to change these interfaces with other ones on both side. As far as I know, to change the interfaces I have to shut down the Port-channel first before i can remove the current Interfaces from it. Afterwards, can I just add the other interfaces and it will work or do I have to configure something else?
Thanks for the help!
Best regards,
Laurent
luis_cordova
Hi @Laurent Soria
A PortChannel can have up to 8 interfaces. Therefore, I suggest you add the 4 new interfaces to the Channel-group first. Then, you can release the current interfaces one by one until there are only 4 new ones left.
luis_cordova
Hi @Laurent Soria
