Changing logging severity in nexus 9000 series switch
Arijit007
We have cisco Nexus 31108PCV Chassis (Nexus 9000 Series) switches, now after adding only logging server we can see it is sending Notification logs only. We want to send the informational logs. The server severity part needs to be 'Informational' How to change that? Below is output of show logging-
Logging console: enabled (Severity: critical)
Logging monitor: enabled (Severity: notifications)
Logging linecard: enabled (Severity: notifications)
Logging timestamp: Seconds
Logging source-interface : disabled
Logging rate-limit: enabled
Logging server: enabled
{x.x.x.x}
server severity: notifications
server facility: local7
server VRF: default
server port: xxx
Logging origin_id : disabled
Logging RFC : disabled
Logging logflash: enabled (Severity: notifications)
Logging logfile: enabled
Name - messages: Severity - notifications Size - 4xxxxx
not sure which parameter you want to change, but the 'logging' command has several options, such as:
dist-sw02(config)# logging console ?
<CR>
<0-7> 0-emerg;1-alert;2-crit;3-err;4-warn;5-notif;6-inform;7-debug
dist-sw02(config)# logging console 5
Baud rate of console should be 38400 to increase severity level
I want to change the server severity line above in the output. it is showing notification.
balaji.bandi
configure logging server host with
(config)# logging server host 6  (host is your syslog server x.x.x.x)
  • 0 – emergency
  • 1 – alert
  • 2 – critical
  • 3 – error
  • 4 – warning
  • 5 – notification
  • 6 – informational
  • 7 – debugging
The default outgoing facility is local7.
BB
