Changing Management Vlan while using VTP?
atlantalan
I have a 6506 core switch running in VTP server mode with a 6504e distribution switch running in VTP server mode as a backup.
My access switches are 2960's running in VTP client mode.
All my access switches can see the vlans as they were created in the Core and I am able to access all vlans on all ports.
Now, I have to setup a way to telnet to these boxes to manage them.
What I did try was to give the vlan 1 interface an ip address starting from the core switch and working my way out. This seemed to work fine except for the routes all seemed to be based on VLAN 1 . Then I read that VLAN 1 should not be used for management. Makes sense to me for numerous reasons. So, I set up a management vlan on the core VTP server. I called it management vlan 11. All the switches see it. I tried to shutdown vlan1 on the access switches and create the vlan11 and give it the IP's I have assigned to each switch. However, since the access switches are in vtp client mode, the change does not seem to take. So, I changed the vtp domain on the access switches temporairly and put the switch into vtp server mode and added the vlan11 to the switch. Then I switched it back to being in client mode. Still no luck.
So, pardon my ignorance and simply being brain dead on something so simple. But, how can I setup a management vlan on the access switch and still have the access switch be a vtp client as this Server/Client seems to work well for us. This is our first VLAN schema so we want to do it right.
ankbhasi
Hi Atlan,
Switch in VTP server or client mode will never affect creating logical layer 3 interface and assigning an ip address to that interface.
Switch in VTP client mode will not allow you to create VLAN at layer 2 but will not restrict you to crrate layer 3 logical interface for management interface.
So when you create vlan 11 at layer 2 on your VTP server it will get propogated to all VTP client switches in your network and then you can create layer 3 interface and assign an ip address and just "no shut" will get the work done.
You need to remember one thing that you need to have trunk between switches carrying vlan 11 or else line protocol for interface vlan 11 will stay down.
Ankur
8 Replies 8
ankbhasi
Hi Atlan,
Ankur
Thank you for your reply Ankur
On my core switch which is running in VTP server mode, I did create vlan 11 (which is going to be my management vlan) and assigned an address of 10.11.1.1 to it. I figured the core is layer 3 and will route anything coming to that vlan.
I do have a trunk between all my access switches and the core and distribution switches. The trunk appears to be working fine between the access switches (2960's) and the core (6506) and distribution switches (6504e) as I am able to assign individual ports on the access switches to any vlan that is proporgated by the VTP servers (the core and distribution switch).
So, on the access switch, how do I create a layer 3 interface when it is a layer 2 switch?
It seems like the answer to my problem was in your response, but I just can't quite get it in my mind. Do you happen to have the commands I can issue on the access switches to do what your talking about.
Again, thanks for responding. It is apprecaited.
Hi Atlan,
You can have only one layer 3 logical interface up and running on your layer 2 switch.
So to create a layer 3 interface on layer 2 switch just run the same command as you do on any layer 3 switch
2960(config)#interface vlan 11
2960(config-int)#ip address
2960(config-int)#no shut
Ankur
*Pls rate the post if it helps
Thank you Ankur,
While your posts did not give me the exact answer, it did give me enough to figure out the issue. I just had to take a minute to think through your explaination.
I went back and started from scratch after your explaination. I rebuilt the management vlan on the VTP server and assigned the int vlan 11 an address
I went to the access switches and shutdown vlan 1 and brought up vlan 11.
Worked fine. I hate it when I get caught up on something so simple. But, thanks for the clarity.
rdanevich
I myself prefer the "Management VLAN" to be the default VLAN1. I think what you're going to need to do in this situation is change the "Native Vlan" i.e. "switchport trunk native vlan 11"
Also, in this type of setup you're gonna have to work from out to in. Go to your furhtest switch, set the trunk port to the native VLAN11, you'll loose connectivity, set the other side of the trunk to native VLAN11.
The VTP server/client is incorrect thinking. Create the VLAN11 on your VTP server this should propogate out to all your clients. "Management" vlan is different then your normal vlans. I apologize that I'm a bit unclear about this, however I know I'm on the right track, we have used other "Management VLANs" other then 1. Hopefully some of the other experts can assist in clearing up my loose ends.
Good Luck!
Thank you rdanevich, I see what your saying and did seriously consider just using vlan 1 as my management vlan 1 as well. I setup VLAN 1 on the core and distributions and the access switches and it did work. But, I noticed that my routes (running eigrp) all changed around to vlan1 routes. Just did not look right to me. Maybe it was right and I am worrying too much about it.
I learned going to the furtherst switch the hard way :) I won't make that mistake again :)
But, I am curious though, if I set both sides of the trunk ports to native vlan 11, would it then allow me to set the ip address of vlan 1 locally? seems to me if the access switch is still in vtp client mode that even assigning an ip to management vlan 11 on the access switch would not work?
I do appreciate your insights though, I am a firm believer that the more thoughts you hear, the more clearer your own become.
I dont agree to above poster. It is not necessary to configure the management vlan as native vlan on the trunk ports. You should be able to assign an IP address on the management vlan using the commands given by Ankur in his post. Once you have given the IP address and have used " no shut " on the interface this will automatically come online.
Let us know the output of the following commands on the access switches
"Show vlan"
"Show interface vlan 11 "
" show interface switchport"
Also let us know that from where i.e which Vlan you rae trying to access the Vlan 11 or the access switches IP. You might have to check for the inter-vlan routing between the vlan if you are on a different vlan.
Please let us know your inputs on this and we will take it form there.
HTH, Please rate if it does.
-amit singh
You know what? I think my "Native Vlan" thinking may have been incorrect. That "Native VLAN" setting has ALWAYS been a confusing subject for me. :-( I think it's more like this, if your "trunking" capabilites went south, then ONLY the "Native VLAN" would be able to communicate. So rather this is a pro-active step if a trunking disaster were to strike, you'd still be able to access your switches remotely.
It is possible to have your "Mangement" IP address in your "Data" range (the IP addresses that your PCs and Printers use). Not good design though (more traffic, broadcasts, bandwidth etc..) Are your switchports configured/set for another VLAN (switchport access vlan 2, switchport access vlan 8, etc...) Is your network using more than one subnet/vlan? Or was it all slapped together in the past by somebody else? Everything defaulting to VLAN 1? Also, I forgot to mention that you'd have to create a subinterface on your router to route traffic for VLAN 11.
I don't understand what you mean by all your routes "changed" around to vlan1 routes. What were they before?
If you do go with the VLAN 11 setup, be sure to REMOVE the IP address from VLAN 1 and shutdown the interface. F.Y.I. My experience has shown me that leaving an IP address in VLAN1 and shutting down the interface still causes a conflict problem when trying to remotely access the switch. Also, if you're going to do this create the commands in a text file then merge the contents into the running config via TFTP. [Example:
interface VLAN1
no ip address
shutdown
interface VLAN11
ip address 10.x.x.x 255.255.255.128
no shutdown
ip default-gateway 10.x.x.1]
Tip: When first doing this, first issue the command "Reload in 15"
That'll give you 15 minutes to make the changes successfully. If successful, issue the "cancel reload" command. Then don't forget to save the running-config to the startup-config.
If unsuccessful wait 15 minutes and the switch will reboot after 15 minutes has gone by thus negating all your changes and going back to the original saved configuration. This may save you a trip or having to call someone for their assistance.
VTP client mode prevents you from creating a VLAN on that switch for the switchports, for the PCs to ACCESS. Management is entirely seperate. "Logical Layer 3 Interface" refers to the management IP address.
Hope this helps for now, waiting for the update. :-)
