Changing Management Vlan
jlong186
Community Member
I'm new to networking and using Packet Tracer to setup a simple network.  When I changed the management vlan from vlan1, I no longer can ping the management vlan.
The network comprises of:
- 1941 router
-  2960 switch
- PC
First, I configured the vlan 1 with an IP address to act as the management vlan.  Below are the IP addresses/info:
- 1941 router, g0/0 = 10.10.10.30/8
   -- connected to switch f0/24
- 2960 switch:
   -- vlan 1 = 10.10.10.20/8
   -- native vlan = vlan 1
   -- f0/24, switchport trunk, dot1q
   -- f0/1, switchport access, vlan 1
- PC = 10.10.10.10/8
   -- gateway: 10.10.10.30
   -- connected to f0/1
From PC, successfully pinged vlan 1(10.10.10.20) & router (10.10.10.30), & vice versa.
Then, I shutdown vlan1 & no ip address.  Native vlan is still vlan 1.  I then created a new management vlan, (vlan 186 = 10.10.10.20) & created vlan 186.  From PC & router, unsuccessfully pinged vlan 186.
Below is the output of "sh int trunk":
Switch#sh int tr
Port        Mode    Encapsulation    Status       Native vlan
Fa0/24    on        802.1q              trunking    1
Port        Vlans allowed on trunk
Fa0/24   1-1005
Port        Vlans allowed and active in management domain
Fa0/24   1,186
Port        Vlans in spanning tree forwarding state and not pruned
Fa0/24    1,186
Can someone please help me figure out  why I can't ping the new management vlan?
8 Replies 8
sathvik k v
Level 6
Level 6
Can you share configuration of port in router and VLAN configuration. Also show vlan.
-Sathvik
Switch#sh vlan br
VLAN Name Status Ports
1 default active Fa0/1, Fa0/2, Fa0/3, Fa0/4
Fa0/5, Fa0/6, Fa0/7, Fa0/8
Fa0/9, Fa0/10, Fa0/11, Fa0/12
Fa0/13, Fa0/14, Fa0/15, Fa0/16
Fa0/17, Fa0/18, Fa0/19, Fa0/20
Fa0/21, Fa0/22, Fa0/23, Gig0/1
Gig0/2
186 VLAN0186 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
why is the trunk port not showing up in VLAN 186?
I hope to understand your question.  The trunk port will not show under vlan 186 using the "sh vlan" command.  Trunk ports will show up using "show interface trunk" command.
Router#sh ip route
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.0.0.0/8 is directly connected, GigabitEthernet0/0
L 10.10.10.30/32 is directly connected, GigabitEthernet0/0
Dennis Mink
No need to use native vlan.
use for instance vlan 100, add vlan100 as the access port vlan. and put an SVI on your router, using vlan 100.
native vlan's confuse most people and 99.99% of the time are used for no good reason.
Please remember to rate useful posts, by clicking on the stars below.
Please bear in mind, I am using Packet Tracer and the setup is very simple network.  The configuration are mostly default setting.  I did not changed nor played with the native vlan.
jlong186
Community Member
Router#sh run
Building configuration...
Current configuration : 616 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524Y77V
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 10.10.10.30 255.0.0.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Switch#sh run
Current configuration : 1150 bytes
version 12.2
hostname Switch
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan186
mac-address 0001.c958.d601
ip address 10.10.10.20 255.0.0.0
line con 0
line vty 0 4
login
line vty 5 15
login
end
