Changing order of IOS in flash
Mustafa Habibi
I have a c2960-24TT-L switch that I have loaded the newest IOS from Cisco’s download site. (c2960-lanbasek9-mz.122-55.SE10.bin) however I cannot get the switch to run the new IOS. As I checked and uploaded into several switch when the new IOS located in below of current one I am facing this issue but when the new IOS comes in above order after reloading the switch the new IOS loads without issue. I also issued the boot string command and instructed to load from new IOS. I checked the show boot command also it is showing me new IOS as well.
If anyone could help me out with the command to changing the order (shifting new IOS to top) that would be greatly appreciated.
switch: dir flash:
Directory of flash:/
2    -rwx  11949374  <date>               c2960-lanbasek9-mz.122-55.SE9.bin
6    -rwx  11941983  <date>               c2960-lanbasek9-mz.122-55.SE10.bin
12855296 bytes available (23891357 bytes used)
18 Replies 18
Training#reload
Proceed with reload? [confirm]
Boot Sector Filesystem (bs) installed, fsid: 2
Base ethernet MAC Address: 00:24:f7:89:4c:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 607 files, 19 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
flashfs[0]: Bytes used: 26233344
flashfs[0]: Bytes available: 6280704
flashfs[0]: flashfs fsck took 12 seconds.
...done Initializing Flash.
done.
Loading "c2960-lanbasek9-mz.122-55.SE10"...c2960-lanbasek9-mz.122-55.SE10: no such device
Error loading "c2960-lanbasek9-mz.122-55.SE10"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/c2960-lanbasek9-mz.122-55.SE9.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "flash:/c2960-lanbasek9-mz.122-55.SE9.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 06-Apr-09 08:36 by amvarma
Image text-base: 0x00003000, data-base: 0x01400000
Initializing flashfs...
flashfs[1]: 607 files, 19 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 32514048
flashfs[1]: Bytes used: 26233344
flashfs[1]: Bytes available: 6280704
flashfs[1]: flashfs fsck took 3 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-24TT-L (PowerPC405) processor (revision F0) with 61440K/4088K bytes of memory.
Processor board ID FOC1307W0GE
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:24:F7:89:4C:80
Motherboard assembly number     : 73-11473-05
Power supply part number        : 341-0097-02
Motherboard serial number       : FOC130709PU
Power supply serial number      : AZS130502YZ
Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C2960-24TT-L
System serial number            : FOC1307W0GE
Top Assembly Part Number        : 800-29859-02
Top Assembly Revision Number    : A0
Version ID                      : V05
CLEI Code Number                : COM3L00BRD
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960-24TT-L    12.2(55)SE9           C2960-LANBASEK9-M
Press RETURN to get started!
Ok, so the switch is looking for a file to boot called "c2960-lanbasek9-mz.122-55.SE10".  There is no file called "c2960-lanbasek9-mz.122-55.SE10" but there is a file called "c2960-lanbasek9-mz.122-55.SE10.bin".  Two different things.
Failing to find the correct file, the switch then boots the FIRST file it "sees" and it's "c2960-lanbasek9-mz.122-55.SE9.bin".
Can you please try this:
config t
boot system flash:c2960-lanbasek9-mz.122-55.SE10.bin
end
wr
And then reboot.
Dear Leo
You are great, many thanks for your kindly cooperation. the issue is solved.
vlausell
Hello there<
The easiest way to deal with this WITHOUT deleting any of the OS files is to tell the switch were to boot from by using the following command
Switch(config)# boot system config-boot.text
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/system_manage/command_reference/b_sm_152ex_2960_x_cr/b_sm_152ex_2960_x_cr_chapter_010.html
