Changing Switch Order in a Stack
MichaelGrech46995
Frequent Visitor
Frequent Visitor
I have built a new Cisco Catalyst 9300 switch stack consisting of four switches.  The order they came up is on the left but the order I want is on the right.  Can I change the order through IOS commands and not remove and restack the switches?  The stack is still new and not in production.  I only have a few devices on the stack for testing.
3     1
1     2
2     3
4     4
Any input would be great.
Michael
M02@rt37
Hello @MichaelGrech46995
Yes you could do that but switch number change would also change the port numbers...
White papier : https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741468.html
Other thread : https://community.cisco.com/t5/switching/9300-stack-renumbering/td-p/4300144
Best regards
Joseph W. Doherty
Or (wink) just externally label each switch member's number.
