Changing the VLAN on stack switches
ankitohc
Hi Expert,
We have three floors. We are using two switches on each floor, and now we have added one more switches on each floor, and all the new switches are added to a stack. I see all the new switch ports showing under management VLAN 1
How can I isolate MGT traffic and move all the ports from VLAN 1 to another master switch VLAN?
aleabrahao
Meraki Community All-Star
I don't understand your question, are you referring to the configuration of the switches' physical ports or the switch's management VLAN?
It got a little confusing.
https://documentation.meraki.com/MS/Other_Topics/Switch_Settings#Management_VLAN
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
Check it out.
https://documentation.meraki.com/MS/Port_and_VLAN_Configuration/Configuring_Multiple_Switch_Ports_on_the_Same_VLAN
CMR
Go to the Switches/Switch ports view, click on all the ports you want to change and change them to access mode and a different VLAN as below:
If my answer solves your problem please click Accept as Solution so others can benefit from it.
