check current processor
hi,
Is there a way to check the current installed processor and its capacity on a cisco switch.
I had checked the show version and output we get is
cisco WS-C3560G-24TS (PowerPC405) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1336W4F1
Could we know whats the capaciy of
cisco WS-C3560G-24TS (PowerPC405) processor (revision D0) and if we need to upgrade it, what are the steps involved.
Our switch is like 89% utilized in terms of processing now.
thanks
Vivk
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If you mean by "upgrade" replace the switch's CPU, that's not done.  Generally the whole switch would be upgraded (or on a chassis switch, perhaps a supervisor card).
If's very unusual to see a L2 or L3 switch with a very high CPU except when there's some "issue".  The reason being, L2 and L3 switch off-load almost all data plane forwarding to dedicated ASICs, the CPU normally only deals with control plane needs.
On the 3560/3750 series, if TCAM resources are exceeded, some ASIC processing is then done by the CPU, which can overtax the latter.
What you might first do is search the main Cisco web site for troubleshooting high CPU utilization on the 3560/3750 series switches.
Yes, that switch servs many service providers, but I had seen it going down till 40 %  for may be 5 minutes and again spiking it back to 89%.
And I had taken the show tech-support output in both cases.
Do You mind to take a look at those logs?
thanks
VIvk
