Need clarification regarding ip address assignment to Vlans
    I want to know one things about methods we can assign ip address to switch virtual interfaces
Core-Switch#sh ip int bri
Interface                  IP-Address      OK? Method Status                Prot
ocol
FastEthernet0/0            unassigned      YES TFTP   administratively down down
FastEthernet0/1            unassigned      YES TFTP   administratively down down
FastEthernet1/0            unassigned      YES unset  administratively down down
FastEthernet1/1            unassigned      YES unset  up                    up
FastEthernet1/15           unassigned    YES unset  up                    down
Vlan1                          unassigned     YES TFTP   up                    up
Vlan100                    172.28.100.3    YES TFTP   up                    down
Vlan110                    172.28.110.3    YES TFTP   up                    down
Vlan120                    172.28.120.3    YES TFTP   up                    down
Vlan130                    172.28.130.3    YES TFTP   up                    down
Vlan140                    172.28.140.3    YES TFTP   up                    down
Vlan150                    172.28.150.3    YES TFTP   up                    down
Vlan160                    172.28.160.3    YES TFTP   up                    down
Vlan200                    172.28.200.3    YES TFTP   up                    down
Damien Miller
Hello Mohammed,
Can you provide a "sh version" and running configuration as well as rephrase your question.  From the outputs that you have provided it is not clear what you are asking for clarification on.
Hi damien,
         for your ref i am posting the output of show version command and Show Run-conf,
Now I will brief my question here . I have a swith configuration file in switch's flash system, I manually copied the config file from flash to a runnig configuration . After copying as a running config from flash, when i checked,  all the virtual interfaces are assigned with ip and but i am not able to ping the Vlan ips
Core-Switch#show vers
Core-Switch#show version
Cisco IOS Software, 3600 Software (C3660-IK9O3S-M), Version 12.4(6)T, RELEASE SO
FTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 23-Feb-06 00:08 by ccai
ROM: ROMMON Emulation Microcode
ROM: 3600 Software (C3660-IK9O3S-M), Version 12.4(6)T, RELEASE SOFTWARE (fc1)
Core-B uptime is 1 minute
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0
x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3660 (R527x) processor (revision 1.0) with 155648K/8192K bytes of memory.
Processor board ID FTX0945W0MY
R527x CPU at 250MHz, Implementation 40, Rev 1.2, 512KB L2 Cache
3660 Chassis type: ENTERPRISE
18 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
125K bytes of NVRAM.
8192K bytes of processor board System flash (Read/Write)
Core-Switch#
The running-configuration is given below :
Core-B#sh run
Building configuration...
Current configuration : 2065 bytes
version 12.4
hostname Core-B
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 5
no ip icmp rate-limit unreachable
ip tcp synwait-time 5
ip cef
no ip domain lookup
spanning-tree vlan 100 priority 16384
spanning-tree vlan 110 priority 16384
spanning-tree vlan 120 priority 16384
spanning-tree vlan 130 priority 16384
spanning-tree vlan 140 priority 8192
spanning-tree vlan 150 priority 8192
spanning-tree vlan 160 priority 8192
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
shutdown
interface FastEthernet1/1
switchport mode trunk
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
no ip address
interface Vlan100
ip address 172.28.100.3 255.255.255.0
interface Vlan110
ip address 172.28.110.3 255.255.255.0
interface Vlan120
ip address 172.28.120.3 255.255.255.0
interface Vlan130
ip address 172.28.130.3 255.255.255.0
interface Vlan140
ip address 172.28.140.3 255.255.255.0
interface Vlan150
ip address 172.28.150.3 255.255.255.0
interface Vlan160
ip address 172.28.160.3 255.255.255.0
interface Vlan200
ip address 172.28.200.3 255.255.255.0
no ip http server
no ip http secure-server
control-plane
--More--
It looks like all your VLANs are in UP/DOWN so it wont ping for sure. We need atleast one interface to be part of the VLANs to bring-up the VLAN.
Please check "show spanning-tree vlan 100" You should see atleast one interface in forwarding state.
Thanks & Regards,
Karthick Murugan
CCIE#39285
Thanks & Regards, Karthick Murugan CCIE#39285
