07-02-2009 05:49 AM - edited 03-06-2019 06:33 AM
Anyone know any good utilities for checking access-lists. Currently we use a manual process to check access-lists when we've changed them.
07-02-2009 03:52 PM
You can use Cisco SDM. Helps to manage, edit etc.
http://www.cisco.com/en/US/products/sw/secursw/ps5318/index.html
07-03-2009 03:50 AM
I am sorry but I do not understand what you mean with "checking access-lists".
If it is syntax then it is quite easy to actually make syntax guidelines and search and replace what youo need to change.
If it is the result of the adding of the access-list how do you want to test it ?
if it is that connections actually get through I tend to use Netcat and it is possible to do that via scriptiong.
however there are limits to what you can test in this way,
Simple tests are quite straight forward but more complex testing needs programming expertise.
