ciro dhcp
nettuno8_20111
Level 4
Level 4
hi I have a router 2901 my problem and this in a 192.168.2.0 network the hosts are all in dhcp and I created a pool that says that the address in dhcp for that host must always be the same, because on that address there I put a deny rule but 'when the host puts the address in a static and change it connects to the internet configuration that I have to do so that even if you put in a static does not connect to the internet?thank you.
Hello
@nettuno8_20111 wrote:
hello yes I know but when the host is in dhcp can not connect to the internet but the problem is when you manually change the ip address that puts another and connects. I would like to make a configuration of the type that even when you change it manually you can not connect to the internet. thank you
conf t
mac access-list extended no-internet
deny host a0f3.c100.0175 any
permit any any
int dailer 1
mac-access group  no-internet in
Kind Regards
Paul
15 Replies 15
Georg Pauwen
what do you need...a static DHCP mapping ? Post the full config of your 2911...
Hello
so please confirm if I have understood -
You have create a dhcp static mapping for a host and that host does not connect to the internet
However if you put the ip address manually on the host it does connect to the internet?
Kind Regards
Paul
Alan Ng'ethe
Level 7
Level 7
So, you are saying that if a static address is configured instead of DHCP address, the host is somehow able to bypass the access list and access the internet? You want access to the internet to be denied regardless of DHCP or static configuration on the host?
Could you please elaborate more and post the configs?
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
hello sorry if I did not send you the configuration in time I could not send the configuration .. yes anyway and as you say ....
iro(config)#do show running-config
Building configuration...
Current configuration : 3798 bytes
! Last configuration change at 15:58:10 UTC Mon Oct 8 2018
version 15.0
hostname ciro
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.2
ip dhcp excluded-address 192.168.2.17 192.168.2.18
ip dhcp excluded-address 192.168.2.49 192.168.2.50
ip dhcp pool vlan-2
network 192.168.2.16 255.255.255.240
default-router 192.168.2.30
dns-server 8.8.8.8 8.8.4.4
lease infinite
ip dhcp pool vlan-1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.60
lease infinite
ip dhcp pool vlan-4
network 192.168.2.48 255.255.255.240
default-router 192.168.2.62
lease infinite
ip dhcp pool deny
host 192.168.1.50 255.255.255.0
client-identifier 01a0.f3c1.0001.75
lease infinite
ip host ciro-isp 192.168.10.2
ip host voice-voip 192.168.10.1
ip name-server 109.232.88.3
ip name-server 109.232.88.4
ip name-server 192.168.10.2
ip name-server 192.168.10.1
ip ddns update method dyndns
HTTP
add http://ciro15:ciro150182@update.dyndns.it/nic/update?system=dyndns&hostname=vegeta.homepc.it
interval maximum 24 0 0 0
interval minimum 24 0 0 0
license udi pid CISCO2901/K9 sn FCZ1523C0C1
vtp mode transparent
vlan 2
vlan 3
name ciro
vlan 4,11
interface Tunnel0
ip address 192.168.3.2 255.255.255.252
tunnel source Dialer1
tunnel destination 95.250.159.118
interface Port-channel2
switchport mode trunk
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
no ip address
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1.11
encapsulation dot1Q 11
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface FastEthernet0/0/0
switchport access vlan 11
interface FastEthernet0/0/1
interface FastEthernet0/0/2
switchport access vlan 2
interface FastEthernet0/0/3
switchport access vlan 4
interface Vlan1
ip address 192.168.1.2 255.255.255.0
ip nat inside
standby version 2
standby 1 ip 192.168.1.60
standby 1 name vlan-1
interface Vlan2
ip address 192.168.2.18 255.255.255.240
ip nat inside
standby version 2
standby 1 ip 192.168.2.30
standby 1 name vlan-2
interface Vlan4
ip address 192.168.2.50 255.255.255.240
ip nat inside
standby version 2
standby 1 ip 192.168.2.62
standby 1 name vlan-4
interface Vlan11
ip address 192.168.10.2 255.255.255.252
ip nat inside
interface Dialer1
mtu 1492
ip ddns update hostname vegeta.homepc.it.dyndns.it
ip ddns update dyndns
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp pap sent-username aliceadsl password 0 aliceadsl
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static tcp 192.168.1.30 34599 interface Dialer1 34599
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.2.16 255.255.255.240 Tunnel0
access-list 101 deny ip host 192.168.1.50 any
access-list 101 permit tcp host 34.255.218.242 eq www any
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
control-plane
line con 0
password ciro
login
line aux 0
line vty 0
password ciro
login
line vty 1 4
login
scheduler allocate 20000 1000
end
ciro(config)#
198/5000
here is the configuration .... when the host user 192.168.1.50 when changing ip connects to the internet. I have to make sure that even when host changes ip you do not have to connect to the internet. thank you
Thanks for the config.
Firstly, you might want to unmark the question as resolved so that someone else may be able to assist you.
Secondly, what IP address does the host 192.168.1.50 have when it is able to connect to the internet?
I do see this line:
access-list 101 deny ip host 192.168.1.50 any;
and this:
which i presume, not 100% sure at the moment, would prevent the translation of host 192.168.1.50 by the nat process, thereby denying internet access.
If that does not deny the translation, then you would probably realize your objective by taking the appropriate measures on the host i.e. denying local users the the ability to change the host's ip address.
I stand to be corrected.
hello thanks for answering me the rule deny 101 192.168.1.50 the setting to prevent that host not to connect to the internet I have also created an ip dhcp pool deny so that the host when receiving the address in dhcp does not connect to internet but 'when the host in question changes the ip address and it takes one free connects to the internet I would like to make sure that even if the address does not change to the internet. for nat 101 it translates other hosts that must be connected to internet.
hello thanks for answering me, the rule 101 deny 192.168.1.50 the setting to prevent that host from not connecting to the internet I have also created an ip dhcp pool deny so that the host when receiving the address in dhcp does not connect to the internet, however, when the host in question changes the ip address and takes one free connection to the internet I would like to make sure that even if the address changes, do not connect to the internet. for nat 101 it translates other hosts that must be connected to internet.
You seem to have done it the right way. In your 'deny' DHCP pool have you tried the hardware-address command instead of the client-identifier command?
hello yes I know thanks .. when the host is in dhcp can not connect to the internet but the problem is when you change it manually, which puts another and connects I would like to make a configuration of the types that even when you change it manually can connect to the internet. thank you
Hello
ip dhcp pool vlan-2
lease infinite
ip dhcp pool vlan-1
lease infinite
ip dhcp pool vlan-4
lease infinite
ip dhcp pool deny
lease infinite
This because you have excluded that host from your NAT translation hence when you change its ip address its able to get natted and access the internet
Kind Regards
Paul
Hello
conf t
permit any any
int dailer 1
Kind Regards
Paul
version 15.0
hostname ciro
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp pool vlan-2
lease infinite
ip dhcp pool vlan-1
lease infinite
ip dhcp pool vlan-4
lease infinite
ip dhcp pool deny
lease infinite
HTTP
vlan 2
vlan 3
name ciro
vlan 4,11
interface Tunnel0
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
ip nat inside
interface Vlan1
ip nat inside
standby version 2
interface Vlan2
ip nat inside
standby version 2
interface Vlan4
ip nat inside
standby version 2
interface Vlan11
ip nat inside
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
no ip http server
ip dns server
control-plane
line con 0
password ciro
login
line aux 0
line vty 0
password ciro
login
line vty 1 4
login
end
ciro(config)#
