Cisco 1760 and 2 WIC cards
toniinformatika
Hello to all,
i have a Cisco 1760 and two WIC cards insite (one is WIC-1ENET and second is Cisco WIC-4ESW) i installed all of them in router.
Now  i want to create vlan's on cards, and i started creating vlan's on  Cisco WIC-4ESW (i created vlan 5-6-7-8, assigned static ip to any vlan  and its vorking).
Now i want to add Ethernet0/0 (WIC-1ENET) to vlan 9 but when i enter command "switchport access vlan 9" it said to me this:
Enter configuration commands, one per line.  End with CNTL/Z.
cisco1760.toni-infor(config)#interface ethernet0/0
cisco1760.toni-infor(config-if)#switchport access vlan 9
% Invalid input detected at '^' marker.
Can  anyone tell me how to fix this and also how to add default  fastethernet0/0 (on cisco 1760) interface to vlan 10 becouse this  command "
switchport access" wont work.
Tnx a lot on help and answers.
radoslav-drabik
Try this
Interface ethernet 0
Switchport
Switchport mode access
Switchport access-vlan 9
Sent from Cisco Technical Support Android App
no help with this switchport command (on this local fastethernet0/0 and ethernet0/0port)
cisco1760.toni-infor(config)#Interface ethernet0
% Incomplete command.
cisco1760.toni-infor(config)#Interface ethernet0/0
cisco1760.toni-infor(config-if)#Switchport
cisco1760.toni-infor(config-if)#Switchport mode access
cisco1760.toni-infor(config-if)#Switchport access-vlan 9
fb_webuser
Level 6
Level 6
Hello
You can not add a vlan to a routed interface, like the 4esw.
The Wic-4esw, is a switch Wic, and the WIC-1ENET is a routed interface that behaves like the interfaces of the router.
To do vlan assigments, do subinterfaces and assing
Posted by WebUser Pedro Seabra Ávila from Cisco Support Community App
