Cisco 1841 advsecurityk9 for CCNA home lab
dnko
I want to create CCNA home lab. For the first time I bought 1841 router:
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 15.1(3)T2, RE LEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 10-Aug-11 03:48 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c1841-advsecurityk9-mz.151-3.T2.bin"
Last reload type: Normal Reload
Cisco 1841 (revision 7.0) with 239616K/22528K bytes of memory.
Processor board ID FCZ112624XC
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62592K bytes of ATA CompactFlash (Read/Write)
Directory of flash:/
1 -rw- 40492396 Jun 3 2020 14:47:30 +00:00 c1841-advsecurityk9-mz.151-3.T2.bin
63881216 bytes total (23388160 bytes free)
1. Is this system good for CCNA 200-301 home lab preparation ?
2. On this system all advanced routing mechanisms are available ? (Or entservicesk9 will be better ?)
Thanks for anyone's help
0 Replies 0
