Cisco 1841 - Weird output at startup
Hamdi Kadri
I have a serious issue with a 1841 router that my boss told me to diagnose. I connect to the console and that's what i get:
Any ideas ?
PS : when I type in the console, I get only these characters (ýøüýøø)
Peter Paluch
Hi Hamdi,
Most often, a similar garbage in a terminal screen is an indication that the speed of the router console is different from the speed of the COM port at your PC. Try simply changing the COM port speed from 1200 through 2400, 4800, 9600, 19200, 38400 and 57600 up to 115200 bps. Every time you change the COM port speed, hit Enter a number of times to see if the router starts responding normally. If it does, and the IOS has booted, I suggest reverting the console speed back to 9600 bps using the following configuration mode commands:
line con 0
  speed 9600 ! The console will hang at this point again
  end
If the console hangs after the speed 9600 command, simply reconfigure your COM port back to 9600 bps and the console should start responding again.
Best regards,
Peter
Peter Paluch
Hi Hamdi,
line con 0
  end
Best regards,
Peter
Hi Hamdi,
Try as Peter Paluch said. I also faced same kind of scenario and it resolved the issue.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
