CISCO 1841 Won't Overload NAT
firemonkey123
Hi all,
Hope I'm not too out of line here. I have Cisco 1841 with software version 12.4. For some reason, nating on dialer interface won't overload. I can only access google and facebook, but not any other site, it will just keep on trying to access the sites. Please see my configuration.
NPCISCO(config)#do sh run
Building configuration...
Current configuration : 1462 bytes
version 12.4
hostname NPCISCO
boot-start-marker
boot-end-marker
enable secret 5 $1$M.16$/6xrCLI7atrsHS5DaLETh1
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.146.1 192.168.146.99
ip dhcp pool LAN
   network 192.168.146.0 255.255.255.0
   default-router 192.168.146.3
   dns-server 119.82.248.67 119.82.249.10
ip name-server 119.82.248.67
ip name-server 119.82.249.10
interface FastEthernet0/0
 no ip address
 ip nat outside
 duplex auto
 speed auto
 pppoe enable
 pppoe-client dial-pool-number 1
interface FastEthernet0/1
 ip address 192.168.146.3 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface Dialer1
 ip address negotiated
 ip nat outside
 encapsulation ppp
 dialer pool 1
 ppp pap sent-username xxxx password 0 xxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip nat inside source list NAT_ADDRESSES interface Dialer1 overload
ip access-list extended NAT_ADDRESSES
 permit ip 192.168.146.0 0.0.0.255 any
control-plane
banner motd ^C###  Athorized Personnel Only ###^C
line con 0
 exec-timeout 0 0
 password xxxx
 logging synchronous
 login
line aux 0
line vty 0 5
 password xxxx
 login
end
Any help would be greatly appreciated as I'm learning cisco currently.
Much thanks
bluestreak66
It seems that you are using a DSL connection connected to fa0/0 although you didn't specify.
If so and you are having issue with some sites and not others as well as a rather slow connection add:
 ip mtu 1452
under interface dialer 1 and I suspect your problem may disappear.
you may also need:
ip tcp adjust-mss 1452
5 Replies 5
Richard Burts
I am a bit puzzled about your problem. In one part of describing the problem you say that the router does not overload - which I assume means that it does not NAT. But then you say "I can only access google and Facebook". It seems to me that if you can reach Google and Faceboot that the router must be doing NAT.
I have two suggestions, though I am not sure that either of them will solve your problem.
- you have nat outside configured on both the Ethernet interface and the Dialer interface. I am not sure why it is on the Ethernet and suggest that you remove that.
- if you are only testing on source interface then why use an extended access list. I suggest that you change the access list and make it a standard access list.
Rick
Rick
Thanks for your suggestions but that didn't work. When I can't get out into the internet first thing come to mind was something wrong with NAT. If I didn't overload NAT, then only 1 person can go out to the internet at least that's my logic. And that it seems what was happening. Anyway, thanks though, Bluestreak's suggestion has solve the problem
I am glad to know that you have resolved the problem. Thanks for posting back to the forum and letting us know that the problem turned out to be an issue with MTU.
Rick
Rick
bluestreak66
 ip mtu 1452
you may also need:
It is working now after added ip tcp adjust-mss 1452 line into to all interfaces. But I notice that the throughput is a little bit slower then when I was using Endian UTM 3.0 firewall. Maybe because cisco 1800 is too old, but I can live with that.
Thank you
