Cisco 1900 series router needs reboot everytime connection is lost
pejibesana
i have a cisco 1900 series router from the isp and we connect it the our router the rv042 small biz, and we have here a cisco catalyst 2950 switch with just default configuration connected to the hosts.
my problem is from time to time that the connection is lost there is no connection with the router and the only solution is to turn off and on the cisco 1900 router and the connection will be back.
do we need to configure the routers and switches? what do you need to configure?
Abzal
Level 7
Level 7
Check memory on the router during lost of connection and cpu usage.
sh memory
sh proc cpu
Abzal
Best regards,
Abzal
Nagendra Kumar Nainar
When you say the connection to router is lost, is it just that the management access to router is lost?. or any traffic traversing the router is also affected?.
if transit traffic is fine, while the management access is not working, it could be related to telnet/ssh session or issue with console not cleared/released properly,(depending on wht mode you use to access the router).
-Nagendra
