cisco 1921 ADSL failover route maps
robertsouthgate
I am trying to get the ADSL failover to work however am not sure if I have the config correct.  It should be able to failover to the NAT and have any interfaces using NAT (such as 1 and 99, be able to use the ADSL), I am not worried about anything else.
I believe the route maps are my issue, but not sure if that is the case as I currently cannot get the VPN to route when at all, it is connected but not able to pass traffic, this I believe is a NAT issue.
track 1 ip sla 1 reachability
 delay down 1 up 2
track 2 ip sla 2 reachability
 delay down 1 up 2
interface GigabitEthernet0/0
 description Connection to EtherFlow Cct ETHA00125935/ETHC00
 ip address x.x.x.x 255.255.255.254
 ip flow ingress
 ip nat outside
 ip virtual-reassembly in
 duplex full
 speed auto
 crypto map xxxxxxxxxxxxxxx
interface GigabitEthernet0/1
 description ** Local LAN **
 no ip address
 ip flow ingress
 duplex auto
 speed auto
interface GigabitEthernet0/1.1
 description native ** Native VLAN **
 encapsulation dot1Q 1 native
 ip address 192.168.101.254 255.255.255.0
 ip flow ingress
 ip nat inside
 ip policy route-map PBR
interface GigabitEthernet0/1.3
 description ** xxxxxx VLAN **
 encapsulation dot1Q 3
 ip address x.x.x.x 255.255.255.240
 ip flow ingress
interface GigabitEthernet0/1.99
 encapsulation dot1Q 99
 ip address 192.168.99.1 255.255.255.0
 ip flow ingress
 ip nat inside
interface ATM0/0/0
 description ** Physical ADSL interface **
 no ip address
 no ip proxy-arp
 no atm ilmi-keepalive
 snmp ifindex persist
 pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Dialer1
 description *** ADSL ***
 ip address negotiated
 no ip unreachables
 no ip proxy-arp
 ip mtu 1452
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname xxxxxxxxxxxxxxxx
 ppp chap password xxxxxxxxxxxxxxxxxxx
 no cdp enable
ip nat inside source list 99 interface GigabitEthernet0/0 overload
ip nat inside source route-map ADSL interface Dialer1 overload
ip nat inside source route-map WAN interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x 10
ip route 0.0.0.0 0.0.0.0 Dialer1 20
ip route 8.8.8.8 255.255.255.255 x.x.x.x
ip route 192.168.102.0 255.255.255.0 x.x.x.x
ip access-list extended xxxxx-VPN
 permit ip 192.168.101.0 0.0.0.255 192.168.102.0 0.0.0.255
ip sla auto discovery
ip sla 1
 icmp-echo 8.8.8.8 source-interface GigabitEthernet0/0
 threshold 1000
 timeout 2000
 frequency 2
ip sla schedule 1 life forever start-time now
ip sla 2
 icmp-echo 8.8.8.8 source-interface Dialer1
 threshold 1000
 timeout 2000
 frequency 2
ip sla schedule 2 life forever start-time now
access-list 99 permit 192.168.99.0 0.0.0.255
access-list 101 deny   ip 192.168.101.0 0.0.0.255 192.168.102.0 0.0.0.255
access-list 101 permit ip 192.168.101.0 0.0.0.255 any
route-map WAN permit 10
 match ip address 1 101
 match interface GigabitEthernet0/0
route-map ADSL permit 10
 match interface Dialer1
route-map PBR permit 10
 set ip next-hop verify-availability 8.8.8.8 1 track 2
route-map PBR permit 20
 set ip next-hop verify-availability 8.8.8.8 2 track 1
robertsouthgate
Anyone have an idea on this at all?
