What is the difference between IPv4 and IPv6?
janakkapadia
Does the latest networking hardware automatically accomodate IPv6 addresses?
5 Replies 5
nkarthikeyan
Level 7
Level 7
Hi Janak,
Yeah it can support automatically in lastest hardwares or some case we need to enable it. But that will give you the IPv4 equivalent IP address in IPv6 format.
But if you want to use the IPv6 segment IP address on the devices. You have to configure it as per the IPv6 standard. So just the compatability between 2 version is enabled.
Karthik
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Automatically?  Usually not, for networking devices.
Usually, network devices need to be configured to support IPv6 just like they need to be configured to support IPv4.
steluck
Hi Janak,
Devices within the past several years are IPv6 capable, meaning they carry support for IPv6 addressing. Since we are still in a stage of transitioning between IPv4 and IPv6, IPv6 must be enabled on most interfaces (through the command ipv6 enable). IPv6 link-local addresses can be automatically configured by way of the router's IPv6 address or manually configured.
Hope this helps!
In order for networking devices to route IPv6 addresses, you must enable ipv6 routing with "ipv6 unicast routing" on your device.  Conversely, the device doesn't need any intervention to receive ipv6 addresses.
jmiddend
Hi janakkapadia -
If you are considering purchasing new networking hardware I would strongly suggest that you check the specifications of whatever products you're interested in to make sure it does support IPv6. However, as "steluk" mentioned earlier most devices today do support the feature albeit needing to be turned on.
Justin
