Cisco 24 port SFP switch with 10g Uplink
rizwankkl
Can anyone please suggest a new Cisco L3 switch with 24 sfp ports and 4 x 10g uplink interface.
I am unsure whether the below part numbers are what I am looking for. please help.
C9300X-24HX
24 Cisco UPOE+, 24x 10G Multigigabit
100M, 1G, 2.5G, 5G, or 10 Gbps
&10 Gig  module for uplink
C9300-24UXB
24 Multigigabit Cisco UPOE (100M/1G/2.5G/5G/10Gbps)
10 Replies 10
switches mentioned by you are ALL multigigabit Copper ports. those are not SFP. for full SFP 24 ports use C9300-24S with C9300-NM-8X (8x 10G SFP) or C9300-NM-4M (4 x multigigabit 10G copper) uplink module
Good luck
KB
THanks, but C9300-24S supports only 1gig but I am looking for all 10gig backplane
What "10gig backplane"?
9300 has a 480 Gbps backplane.
9300X has a 1.0 Tbps backplane.
Any other preferred model would you suggest? instead 9300 series..
9400's are quiet expensive..
24-port SFP+ capable switch, the cheapest is the 9300X-24Y.
Uplink module would be C9300X-NM-8Y.
Leo Laohoo
What speed of optics, 1- or 10 Gbps?
10 gig
balaji.bandi
C9300X-24HX    support all SFP port - make sure you mentioned Ethernet or Fibre ports
All NM Module support, but if you looking all 10GB port i would expect uplink should be 40 or 100GB to best outcome.
Table 3.        Network module numbers and descriptions
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
BB
Thanks, I hope C9300-24-HX supports our requirement..
we will use 24 x 10 gig fiber sfp and 10g for uplink.
yes that is the requirement, as i suggested you may see uplink may have bottleneck when you fully populated 10GB ports.
BB
