Hi All,
I am currently running Cisco 2800 ME version 8.8.120.0 and have 4 AIR-AP2802I-E-K9 in the environment. Since the setup has been installed we have regular reports of clients disconnecting and when they reconnect everything is fine.
The AP's are running full POE, and when checking the AP stats, there has been no reboot, no active interferers all signs look good? I have read in some cases that random disconnects may have something to do with the WLAN timeout setting but when checking the advanced settings of the WLAN there is no option for this.
The WLAN config is pretty straight forward, running 5Ghz only with external radius for authentication, and vlan tagging. The rest of the options are default. The switchport configuration (C9200-48P) is also pretty standard, trunk and native vlan set
Is anyone else experiencing this?
