Cisco 2801 Question
Jherrera1004
the Goal i'm trying to achieve is having a Cisco outer 2801 (which is the internet ip: 75.150.67.105) open a port 3001 tcp to give internet to another cisco device with a IP of 172.16.8.40
interface FastEthernet0/0
ip address 75.150.67.105 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly in
zone-member security public
duplex auto
speed auto
crypto map vpn
I've try doing NAT, below is what i've try so far:
access-list 1 permit 170.163.0.0 0.0.255.255
access-list 1 remark for Telnet & SNMP Restrictions
access-list 1 permit 172.16.8.0 0.0.3.255
access-list 7 permit 172.16.8.40
access-list 7 permit 172.16.8.41
access-list 7 permit 172.16.8.42
access-list 7 permit 172.16.8.43access-list 10 permit 75.150.67.105
access-list 20 permit 170.163.128.202
access-list 102 deny   ip any 10.0.0.0 0.255.255.255
access-list 102 deny   ip any 172.16.0.0 0.15.255.255
access-list 102 deny   ip any 192.168.0.0 0.0.255.255
access-list 102 permit ip 172.16.0.0 0.0.15.255 any
access-list 102 permit ip 172.16.0.0 0.15.255.255 any
access-list 110 permit ip any any
access-list 111 permit ip 172.16.251.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 111 deny   ip any any
ip local policy route-map LocalPBR
ip local pool vpn_ip 172.16.251.10 172.16.251.20
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 172.16.8.40 3001 172.16.250.1 3001
ip nat inside source route-map NAT-HFC interface FastEthernet0/0 overload
ip nat inside source route-map NAT-OPT interface Vlan413 overload
ip route 0.0.0.0 0.0.0.0 75.150.67.106 track 3
ip route 0.0.0.0 0.0.0.0 170.163.128.201 5
thanks in advance
Mukesh Kumar
Level 3
Level 3
Hello Jherrera1004
Can you please clear this question?
Do you want to access 172.16.8.40 from ISP end or do you want to provide internet access to this ip address?
Mukesh Kumar
Network Engineer
Spooster IT Services
Sorry, I didn't wrote the question correctly. I want to provide internet access to the 172.16.8.40 via the 3001 port from the cisco 2801
This is what i tried so far:
access-list 7 permit 172.16.8.40 0.0.0.43
