Cisco 2801 Series Router Not Connecting Users to Internet
Edgar Panduro
I have a Cisco 2801 series router, and I would like to connect router to Internet and act as a gateway to the Internet for my users on the LAN network. So far I've configured both FE ports, and still my users don't have Internet access.
On Cisco router I did a sh run, and my output is below.
interface FastEthernet0/0
description ##Internet##
ip address dhcp
ip access-group MY_WAN in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description ##My LAN##
ip address 192.168.0.12 255.255.255.0
ip nat inside
duplex auto
speed auto
I used this link https://supportforums.cisco.com/t5/lan-switching-and-routing/how-do-you-connect-a-cisco-router-to-the-internet-through-a/td-p/2242370  to configure my router. Not sure what the problem is. So far we know router is working because its giving out IP addresses. Router can ping users on LAN, and users can ping router. But router cannot ping ISP router.
Any suggestions on how properly configure router so users on LAN can access Internet?
13 Replies 13
Hi Edgar,
1) Could you ping internet from the router?
2) Did you receive IP address from your ISP? You can run "sh ip int bri" to check.
3) If your answer is yes for the above questions, please share the output of "sh run".
HTH,
Meheretab
HTH,
Meheretab
Hi Meheretab,
1) Router cannot ping Internet
2) I'm not receiving an IP address from ISP router
3) When I run "sh ip int "I see no DHCP IP address
4) Below is output, when I run "sh ip int"
Router#sh ip int
FastEthernet0/0 is up, line protocol is up
Internet address will be negotiated using DHCP
Broadcast address is 255.255.255.255
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound access list is MY_WAN
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is enabled, interface in domain outside
BGP Policy Mapping is disabled
Input features: Stateful Inspection, Virtual Fragment Reassembly, Access List, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
Output features: CCE Output Classification, Post-routing NAT Outside, Stateful Inspection
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
FastEthernet0/1 is up, line protocol is up
Internet address is 192.168.x.x/24
Address determined by non-volatile memory
MTU is 1500 bytes
Inbound access list is not set
Network address translation is enabled, interface in domain inside
Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
Output features: NAT Inside, Stateful Inspection
Serial0/2/0 is administratively down, line protocol is down
Internet protocol processing disabled
Serial0/2/1 is administratively down, line protocol is down
BRI0/3/0 is administratively down, line protocol is down
BRI0/3/0:1 is administratively down, line protocol is down
BRI0/3/0:2 is administratively down, line protocol is down
NVI0 is administratively down, line protocol is down
SSLVPN-VIF0 is up, line protocol is up
Interface is unnumbered. Using address of SSLVPN-VIF0 (0.0.0.0)
MTU is 1406 bytes
IP fast switching is disabled
IP CEF switching is disabled
IP Null turbo vector
IP multicast fast switching is disabled
Network address translation is disabled
Input features: MCI Check
Edgar,
Since you are not receiving IP address from your ISP on your gateway, you will not have Internet access. The first thing I would do is contact the ISP and troubleshoot with them why IP address is not issued.
Once you get IP address, if you still have connectivity issue, you will need to check George's and Julio's advice.
HTH,
Meheretab
HTH,
Meheretab
Meheretab,
It's not an ISP issue. I have a Cisco ASA 5505 Series firewall and it's able to receive DHCP IP address from ISP router.
My Cisco ASA 5505 is on a different LAN then my router.
Try and replace:
ip address dhcp
with
ip address negotiated
you need to have at the very least the three lines in bold in your configuration:
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
ip nat inside source list 1 interface FastEthernet0/0
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
access-list 1 permit 192.168.0.0 0.0.0.255
Additional to Georg's config, is this ACL being used: ip access-group MY_WAN in? it could be removed.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Georg,
I added the three lines to my config and still no Internet access. Also, port fa0/0 which is connected to ISP router is not receiving DHCP IP address.
I think port fa0/0 is the reason why we can't access the Internet.
Actually, try the below:
pppoe-client dial-pool-number 1
interface dialer 1
ip mtu 1492
encapsulation ppp
ppp authentication chap
dialer pool 1
dialer-group 1
ip nat inside source list 1 interface Dialer1 overload
dialer-list 1 protocol ip permit
ip route 0.0.0.0 0.0.0.0 Dialer1
Hi Georg,
I entered your lines of code, and still no luck. You think maybe I need to set ACL for Outgoing access? I ran a sh ip int, and port fa0/0 still isn't getting DHCP IP address. You think maybe I need to add ISP gateway address?
to avoid confusion, post the full configuration you have right now. I have lost track of the changes you made, and something essential might be missing...
Sure my output is below.
Router#sh run
Building configuration...
Current configuration : 1818 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.x.x 192.168.x.x
ip dhcp pool My_LAN
network 192.168.x.x 255.x.x.x
default-router 192.168.x.x
dns-server 209.18.x.x 209.18.x.x
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
ip address dhcp
ip nat outside
duplex auto
speed auto
pppoe enable
ip address 192.168.x.x 255.x.x.x
ip nat inside
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
no fair-queue
clock rate 2000000
interface Serial0/2/1
no ip address
shutdown
clock rate 2000000
interface BRI0/3/0
no ip address
encapsulation hdlc
shutdown
interface Dialer1
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list My_LAN interface FastEthernet0/0 overload
ip access-list extended MY_WAN
permit tcp any any established
deny tcp any any
permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router#
I have adjusted your configuration. Below are two configurations, one for PPPoE with a dialer interface, the other for direct Ethernet access. Try them both, and make sure that they look EXACTLY like I posted them:
Configuration 1
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool My_LAN
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
duplex auto
speed auto
pppoe enable
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
clock rate 2000000
no ip address
shutdown
clock rate 2000000
interface BRI0/3/0
no ip address
encapsulation hdlc
shutdown
interface Dialer1
ip nat outside
ip mtu 1492
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
access-list 1 permit 192.168.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Configuration 2
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool My_LAN
ip cef
no ipv6 cef
voice-card 0
archive
log config
hidekeys
ip address dhcp
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
no ip address
shutdown
no fair-queue
clock rate 2000000
no ip address
shutdown
clock rate 2000000
interface BRI0/3/0
no ip address
encapsulation hdlc
shutdown
no ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
control-plane
line con 0
line aux 0
line vty 0 4
login
end
