VSS dual-active active detection ePAgP
andreagabellini
I have two VSS systems, core_01 and core_02, connected with a port channel. Can I use this port channel with epagp for dual active detection of both systems?
Something like this:
core_01:
interface port-channel 20
switchport
switchport mode trunk
switch virtual domain 10
dual-active detection pagp
dual-active trust channel-group 20
core_02:
switchport
switch virtual domain 12
Andrea
Reza Sharifi
I have never used a second set of VSS switches for dual active detection but I think it should work as its just a trunk port. On the other hand, you can use fast hello for each set and not worry about ePAgP at all if your IOS supports it.  Fast hello is so much easier.
