CISCO 2811 and EHWIC-VA-DSL-A=
heathtrengove
I am having trouble setting up a EHWIC-VA-DSL-A= card on my cisco 2811 running the following the following:
c2800nm-adventerprosek9-mz.151-4.M2.bin and C2800NM_RM2.srec.124-13r.T11
My hardware supplier tells me its the right adsl card (have 1 existing working card not the same) but the card will not detect on the system to be configured.
is this the right card? am I missing something?
Peter Paluch
HI Heath,
It seems that this card is not supported in 2811 routers. According to the following datasheet:
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78-644629.html
the card is supported only on 1861E and then only on 19xx/29xx/39xx platforms. It is not supported on 2800 series routers, unfortunately.
Perhaps this list of supported modules and interfaces will help you to choose the correct DSL module:
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
Best regards,
Peter
Neeraj Arora
Level 3
Level 3
Heath,
As per the documentation EHWIC modules were only supported in ISR-G2's (1900,2900,3900 series routers), so this module would not work with 2811 router
I checked the following documents for reference:
** 2800 Series router Interfaces and Modules
** Cisco Multimode VDSL2 and ADSL2/2+ High-Speed WAN Interface Card Datasheet
http://www.cisco.com/en/US/prod/collateral/routers/ps10536/data_sheet_c78-644629.pdf
I thnk you need to double check with your supplier about your router's compatibility with this DSL module
Hope it helps
Neeraj
