HSRP, GLBP and VRRP
macfrist38
Hi all,
Please i want to config one of these three redundancy protocol but i want to know if we can config it based on connection bandwith, if i have 2 Internet connection with 256 kbps each and if one of these connection decrease (not failed) it can use another side.
thanks for help
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
Determine whether your devices supports OER/PfR.
Ven Taylor
Level 4
Level 4
Those won't work the way you'd like them to work.  You may want to research IP SLA and see if it works for you.
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html
Ven
Ven Taylor
thanks i will look out
thanks
Joseph W. Doherty
Disclaimer
Posting
