Cisco 2811 giving strange console output
mbroberson1
Level 3
Level 3
I have a Cisco 2811 giving the following strange console output. I have another Cisco 2811 that is giving normal console output. I am using the typical console settings, it's very strange.
"Τ@(
     Ão!}rBÌ9üÿ#ˆ—Ç+ç‘Úø"nü
                           ÌÉÆþ1G1®þaÇ
                                       ÛO¶ûÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"Y!ŠÁÊ
Brandon
InayathUlla Sharieff
Try multiple speed settings starting at 2400 baud ,then 4800 , 9600 , 19200, 38400,  double each setting up to 115200  and see if you get any response
Also try any other console cable if you have.
Inayath
Inayath
Ok...finally I get some screen output. When I use baud 115200 I get the following.
monitor: command "" not found
rommon 2 >
rommon 2 >
Robert Craig
Level 3
Level 3
If I'm not mistaken, the word baud has to be all capital letters.
