USB to Serial adapter connection
cisco steps
I have a iBook G4. Console cable, and USB to Serial adapter cable. I would like to be able to console into a Cisco router, I am using Zterm as was recommanded early for Hyperterminal. it seems that the connection is there. when I click on the Zterm app I get a blank white screen with
ATE1 V1
OK
any one have any idea how to use this terminal or help get connected
I know that I can use Terminal to telnet into the router, but I need to console in first to set up the basic configuration.
2 Accepted Solutions
Hi Karim,
I am very glade that you did it :) please do enjoy your lab, i'll always be here if you have further problems, and thanks for the nice rating.
HTH,
Mohammed Mahmoud.
17 Replies 17
guruprasadr
Level 7
Level 7
HI,
You can use "Hyperterminal" for this kind of Setup.
Setup as below:
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
PLS RATE if HELPS
Best Regards,
Guru Prasad R
mohammedmahmoud
Level 11
Level 11
Hi Karim,
For Zterm, generally configure 9600 baud, 8 bits, no parity, 1 stop bit and you must select usbserial if you're using a usb-to-serial converter.
HTH,
Mohammed Mahmoud.
It shows to me as either Com3 or Com4
Narayan
cisco steps
thanks for the reply all of you, the issue that I have is where I can configure all this >>>>
Bits per sec : 9600
Data bits : 8
Parity : none
Stop bits : 1
Flow control : none
the Screen is blank so how I will configure it ..I do not see any options where I do that ..
I did some digging and here is one of the answers , have not try it yet , but will let you know . late on today.. Thank you all
http://www.planet-rcs.de/en/article/mac_serial_port/
Hi Karim,
As illustrated in the link you've found, first you need to go to settings -> Modem Preferences -> select usbserial0 as the default modem and then edit your connection parameters as said in earlier posts, and it should be that simple.
HTH,
Mohammed Mahmoud.
cisco steps
I did try to follow the instructions but when I look for serial0 under modem prefrences there is only modem ..I did attach the snapshot,, Thanks ,
any one can help with this one please / Thanks
Hey Karim,
How do you do :), you'll need to make sure that you've installed the driver for the usb-to-serial converter.
HTH,
Mohammed Mahmoud.
Mo .. I did buy a generic usb/serial and it did not come w/ the driver... do I have to buy an other one// Thanks
Hi Mo
I did try to download the driver but I get a Chinese characters. I will try it again today... Tanks
That did it Mo .. thanks for taking your time to help me with the issue. it works better then windows hypererminal.. :-)
Hi Karim,
HTH,
Mohammed Mahmoud.
