Cisco 2811 IOS file not appearing on flash drive
Arber_123
Hi everyone,
I'm having an issue with a Cisco 2811 ISR Router. Sh ver command output lists the correct ios that the router used for booting and it says that the ios is stored in flash but when i give "sh flash" command it doesn't display the ios file. It seems weird to me.
Maybe the flash is corrupted or damaged in some way? Has anyone any idea about this? In the attached file is the output from the "sh ver" and "sh flash" commands.
Your help is very appreciated.
Best regards,
Arber Mancaj.
6 Replies 6
Raphael Wouters
Hi Arber,
I don't expect the file system to be corrupted, it would have displayed an error. We can see the flash has some space used so I believe the image is in there.
I'm not sure what is your problem here. Can you try a "show flash all", "dir flash:" and "dir /all"?
Do you get something while you try "show file information flash:c2800nm-adventerprisek9-mz.124-22.T5.bin"?
Maybe you don't have some privilege right to display the files, are you in enable 15? ("show privilege")
Here is the output of the suggested commands. I even tried an IOS upgrade and reformatting the entire flash but nothing changed. i can copy and move correctly in flash (tried creating a directory, copy nvram:startup-config flash) and everything looks normal. just the IOS file doesn't display in the show commands.
CCSS#sh privile
Current privilege level is 15
CCSS#sh flash all
-#- --length-- -----date/time------ path
5267456 bytes available (58716160 bytes used)
******** ATA Flash Card Geometry/Format Info ********
ATA CARD GEOMETRY
   Manufacturer Name
   Model Number           STI Flash 7.4.0
   Serial Number          STI J18f106303221058
   Firmware Revision      02-10-06
   Number of Heads        8
   Number of Cylinders    490
   Sectors per Cylinder   32
   Sector Size            512
   Total Sectors          125440
ATA PARTITION 1 INFO
   Start Sector           32
   Number of Sectors      125408
   Size in Bytes          64208896
   File System Type       FAT16
   Number of FAT Sectors  62
   Sectors Per Cluster    8
   Number of Clusters     15621
   Number of Data Sectors 124968
   Base FAT Sector        140
   Base Root Sector       264
   Base Data Sector       296
ATA MONLIB INFO
   Image Monlib size      118028
   Disk Monlib Size       67320
   Disk Space Available   71168
   Name                   piptom-atafslib-m
   Start sector           2
   End sector             133
   Updated By             C2800NM-ADVENTERPRISEK9_IVS-M12.4(11)XW7 <--------    This was the old version of IOS
   Version                1
CCSS#sh file information flash:c2800nm-adventerprisek9-mz.124-22.T5.bin
%Error opening flash:c2800nm-adventerprisek9-mz.124-22.T5.bin (File not found)
CCSS#
CCSS#dir /all flash:
Directory of flash:/
No files in directory
63983616 bytes total (5267456 bytes free)
CCSS#
BTW can the router boot the IOS from an USB flashdrive.
Yes.  You need to upgrade your bootstrap to 12.4(13r)T6 or later to support boot-via-USB.  Take note that maximum USB size supported is 2Gb.
Forget it.  Based on your attachment the IOS file is missing.  Upload the correct IOS before something happens.
Timor_SSS
Hi Arber,
Show ver display the info from the last boot. It means that last time that that ISR booted he used the IOS image that was located on flash. It doesn't mean that it's still there.
I suspect that someone deleted this image form flash. If you reboot the ISR now, I don't think that it'll boot up.
BR,
Timor Sherf
Nabaruma
Hi Arber,
Does your router comes with a compact flash? It looks like it has from your attachment!
try the following command: sh disk1:
Also try the command sh dir /all
Probably the ios reside in the external flash as usual with the new routers.
byroncarrion
I also had this issue with my cisco 2811 routers.
The behaviour is very strange because you can boot the router, but when you try to list the files in the flash nothing appears. It's due to Cisco IOS Resilient Configuration.
You can see more about it here:
http://www.cisco.com/en/US/docs/ios/sec_user_services/configuration/guide/sec_resil_config.html
All that you need to do is: Router# show secure bootset
If the output show the resilient configuration enabled, disable it by typing Router(config)#no secure boot image.
But if the output doesn't show anything. You will need to do the following:
- Router(config)#secure boot image
and then
- Router(config)#no secure boot image
After that you will be able to see the image in the flash again.
See you
Byron
