cisco 2821 fan issue
Network Pro
We have a Cisco 2821 and looking at the logs
043669: Jun 19 12:14:23.795 CEST: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
043673: Jun 19 12:14:53.795 CEST: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
043678: Jun 19 12:15:23.795 CEST: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
043684: Jun 19 12:15:53.796 CEST: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
043689: Jun 19 12:16:23.796 CEST: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Test#sh envi
Main Power Supply is AC
Fan 1 OK
Fan 2 Low RPM
Fan 3 OK
Fan Speed Setting: Normal
System Temperature: 28 Celsius (normal)
Environmental information last updated 00:00:02 ago
Is this low risk or does this router need changing? I dont have Cisco support to RMA
6 Replies 6
Reza Sharifi
This seems to be a cosmetic bug as the "sh env" shows everything is ok with the device. An IOS upgrade will most likely solve the issue but if you don't have support then you should be fine with what you have.
show env says "Low RPM"? will that be an issue?
There is nothing you can do if there is no Service Contract to replace the fan assembly.
You may want to turn off the router and clean the fans to make sure dust or dirt is not clogging the fans.
Also, have a look at this link:
https://support.hpe.com/hpsc/doc/public/display?docId=mmr_kc-0129171
understand this, ths router is off site and i cant get there - my question is it risky to leave it like this or does this need immidieate attention to replace?
A router is fully dependent of the fan to keep the motherboard clean. If the fan isn't functional, then the temperature of the CPU will increase. And no one wants to see a very expensive router with a melted CPU.
