05-20-2016 12:21 PM - edited 03-08-2019 05:52 AM
Hi everyone,
i have cisco 2821 router. i am facing booting problem.
anybody suggest me what is the problem.
thanks in advance......
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
Initializing memory for ECC
c2821 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x26bc2cc
Self decompressing the image : #################################################
################################################################# [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E8 0X003DA000 C2821 Mainboard
0001AB 0X0025178C 1A E3
0X00263F50 Onboard VPN
0X000021B8 Onboard USB
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00D65284
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 14Mb.
Using 5 percent iomem. [14Mb/256Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T7
, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 16:35 by prod_rel_team
Image text-base: 0x400B1E74, data-base: 0x434A9AC0
****** ERROR detected on PCI1 Bus
****** Try RESEATING all modules in the system
****** pci1_int_cause 0x00000240,
****** pci1_err_addr 0x00091009, pci0_err_cmd 0x0000000A
****** PCI Master Read Parity Error
PCI Target Abort
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 45C80000 r4 = 0
r5 = 303 r6 = 0 r7 = 1 r8 = 0 r9 = 100000
r10 = 0 r11 = 465E4369 r12 = 0 r13 = 465E436A r14 = 0
r15 = 8 r16 = 0 r17 = C100 r18 = 0 r19 = 3400C101
r20 = 0 r21 = 40096828 r22 = FFFFFFFF r23 = FFFF00FF r24 = 0
r25 = 469AAC64 r26 = 0 r27 = 469AAC60 r28 = 0 r29 = 469AAC5C
r30 = 0 r31 = 469AAC58 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = 469AACD0
r50 = 0 r51 = 0 r52 = 0 r53 = 3040A801 r54 = FFFFFFFF
r55 = A000F000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 465E4358
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 402E4B10
sreg = 3400C103 mdlo_hi = 0 mdlo = 251C00
mdhi_hi = 0 mdhi = 0 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 402E4B08 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages (02:37:51 UTC Wed May 18 2016) ===
Queued messages:
02:37:51 UTC Wed May 18 2016: Interrupt exception, CPU signal 22, PC = 0x0
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback=
$0 : 00000000, AT : 00000000, v0 : 00000000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 00000000, s2 : 00000000, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 00000000, sp : 00000000, s8 : 00000000, ra : 00000000
EPC : 00000000, ErrorEPC : 00000000, SREG : 00000000
MDLO : 00000000, MDHI : 00000000, BadVaddr : 00000000
CacheErr : 00000000, DErrAddr0 : 00000000, DErrAddr1 : 00000000
DATA_START : 0x434A9AC0
Cause 00000000 (Code 0x0): Interrupt exception
Writing crashinfo to flash:crashinfo_20160518-023752
No warm reboot Storage
*** System received a System Error ***
signal= 0x16, code= 0x0, context= 0x46905718
PC = 0x40096d7c, Cause = 0x20, Status Reg = 0x34008002
Solved! Go to Solution.
05-20-2016 07:19 PM
Ok, the router is running on a "T" train.
PCI Target Abort
Remove any any NM/NME or WIC/HWIC cards and reboot again. If the router is able to boot correctly, upgrade the router to a higher version. DO NOT use another "T" train unless it is necessary. Use an "M" train instead.
05-20-2016 07:19 PM
PCI Target Abort
05-22-2016 03:45 AM
