Cisco Nexus 40G Uplinks with vpc bandwidth test
ositechintl
I two Nexus 9K switches and two Nexus 3K switches which is cross connected with QSFP+ (40G Uplinks) cables.
Which means technically i have 160 GB which is bundled together.
I am using vpc (virtual port channel) to bundle the Nexus 3K switches on one end and Nexus 9K switches on the another end.
I want to check the bandwidth speedtest between Nexus 9K to Nexus 3K.
Ramesh
ositechintl
I used to test the uplinks bandwidth test between catalyst switches Test TCP (TTCP). If there is any tool is there like to find the speed test on Nexus uplinks.
Ramesh
You can use a trial version of IxChariot from ixia. Ixia has excellent testing tools but a bit pricey.
https://www.ixiacom.com/products/ixchariot
