Cisco 2821 - Stop Inter-vLan Routing
leacho73
Hi Everyone,
I have a number of subinterfaces on my Cisco 2821 router - and I was wondering if there was any way to stop routing between the different interfaces - here is an example:
G0/1.1 - 192.168.0.254/24
G0/1.2 - 10.10.10.254/24
G0/0.1 - 10.10.20.2/30
G0/0.2 - 10.10.30.2/30
G0/0.1 connects to an ASA5520 firewall with an address of 10.10.20.1
G0/0.2 connects to a separate port on the same firewall with an address of 10.10.30.1
I want to be able to route all traffic destined for a sub interface - up to my ASA for firewall inspection, and then route it back down to the correct sub-interface. I would expect the traffic to route as follows:
192.168.0.1 -> 192.168.0.254 -> 10.10.20.2 -> 10.10.20.1 -> Firewall Rule Inspection -> 10.10.30.1 -> 10.10.30.2 -> 10.10.10.254 -> 10.10.10.1
Hope that makes sense?
Matt
6 Replies 6
marce1000
  - No it doesn't make sense, a firewall should be a 'full hop' in the routing-path , preferably at either edge ( w.r.t incoming or outgoing traffic).
M.
Basically, I want to separate out traffic steams that naturally land on the 2821 - but forward them up to the firewall for inspection - hint the 2 port's on the firewall.
I have tried subinterfaces on the firewall, but I found that I was getting packet drops all the time, so wanted to stick with physical interfaces.
Matt
Hello Matt,
I am not really clear on what you are asking. All interfaces are directly connected, so routing between them is automatic. You can use access lists on the (sub) interfaces to allow/disallow one to talk to another...
Deepak Kumar
All interfaces are directly connected so routing is the default behavior of "Router". But you can use "ACL" to block traffic between your subinterfaces with deny statements.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
mlund
Level 7
Level 7
If you split your router into two logical routers by using vrf:s, you can accomplish what you want.
First create 2 vrf , for example vrf inside and vrf outside ( inside and outside is just names, you can call them adam and brian if you want).
Then assign interface g0/1.1 and g0/0.1 to vrf inside
Assign interface g0/1.2 and g0/0.2 to vrf outside.
Then put in routing into each vrf for example
ip route vrf inside 10.10.10.0/24 10.10.20.1
ip route vrf outside 192.168.0.0/24 10.10.30.1
/Mikael
As Mikael has described, VRFs are probably the solution you're looking for.
BTW, by default, when you use VRFs (sort of the L3 equivalent of VLANs), you already have a "global" unnamed VRF, i.e. you don't actually need to define two, you could do similar to what Mikael suggests just by defining an additional VRF.
