Cisco 2821 will not boot from flash
calkins.t
I have a 2821 that will not boot from any CF.  I have confirmed that the CF are in good working order by using them in another 2821.  The bootup looks like this...
System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
Initializing memory for ECC
c2821 processor with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
device does not contain a valid FS
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
rommon 1 >
I have even formated a new CF and copied an IOS to it.  That did not work either.
19 Replies 19
all working now?
Did you try using the fsck command if it exists from rommon mode? I have the same problem on a C2950 and it was solved after that file system check.
Regards.
Kevin Brennan
Can you do a one time boot of your IOS from a USB memory device and then try formatting the card in-situ?
Kevin
USB-boot support starts with bootstrap version 12.4(13r)T6.
Please don't forget to rate useful posts.  Thanks.
Apologies, I missed that bit.
Kevin
