02-19-2018 10:34 AM - edited 03-08-2019 01:55 PM
I have new CISCO2911/K9 router and installed VIC2-4FXO on it, I can see all 4 ports are orange lighting, I need to configure 2 ports connected to PABX and other 2 ports to PSTN, I have the config from another router, but the issue is when I type command "voice-card 0" it says invalid command.
I tried to change the license from default ipbase to uck9, the command "voice-card 0" worked but another command "voice-port 0/3/0" not working, so do I need to type command that activate FXO module and which license/image should I use in order to configure the voice ports (you can see below config example from another router running perfectly).
show version shows these licenses and image:
c2900-universalk9-mz.SPA.154-3.M3.bin
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data None None None
NtwkEss None None None
CollabPro None None None
show inventory
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO , VID: V03
Config example:
voice-card 0
voice service pots
voice service voip
fax protocol none
sip
min-se 90 session-expires 90
session refresh
no call service stop
voice-port 0/3/0
secondary dialtone
no battery-reversal
timeouts initial 8
timeouts interdigit 5
timeouts call-disconnect 1
timeouts ringing 5
timeouts wait-release 2
timeouts power-denial 5
description 2-wire analog connection to PABX
station-id number xxxx
voice-port 0/3/1
secondary dialtone
no battery-reversal
timeouts initial 8
timeouts ringing 5
voice-port 0/3/2
secondary dialtone
no battery-reversal
timeouts initial 8
timeouts ringing 5
description PSTN
voice-port 0/3/3
secondary dialtone
timeouts initial 8
timeouts ringing 5
description PSTN
mgcp profile default
dial-peer voice 20 voip
destination-pattern x....
session protocol sipv2
session target ipv4:x.x.x.x
dtmf-relay sip-notify
codec g711alaw
no vad
dial-peer voice 2 pots
description PABX connection
destination-pattern x[0-9].....
port 0/3/0
forward-digits x
dial-peer voice 3 pots
port 0/3/1
forward-digits x
sip-ua
keepalive target ipv4:x.x.x.x
keepalive trigger 10
retry bye 5
retry keepalive 5
retry options 5
timers keepalive down 15
timers keepalive active 15
timers options 300
gatekeeper
shutdown
02-19-2018 10:36 PM
show inventory output is below
NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: XXXXXXXX, Hw Revision: 1.0"
PID: CISCO2911/K9 , VID: V08 , SN: XXXXXXXXX
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: XXXXXXXXXXXX
PID: VIC2-4FXO , VID: V03 , SN: XXXXXXXXX
NAME: "SM-X-ES3-24-P: EtherSwitch SM L3 + PoEPlus + MACSec + 24 10/100/1000 on Slot 1", DESCR: "SM-X-ES3-24-P: EtherSwitch SM L3 + PoEPlus + MACSec + 24 10/100/1000"
PID: SM-X-ES3-24-P , VID: V01 , SN: XXXXXXXXX
NAME: "C2911 DC Power Supply", DESCR: "C2911 DC Power Supply"
PID: PWR-2911-DC , VID: V01 , SN: XXXXXXXXX
