Cisco 2911 Fan issue or Motherboard issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-19-2012 10:32 AM - edited 03-07-2019 10:07 AM
Wondering if anyone can provide a little information on a possible issue that I am having with a Cisco 2911 Router. Over the weekend we received SNMP fan alerts.
Here is what Show Environment reports. My question is about the FAN TRAY: MISSING. Has anyone seen this before? Could bne a simple fan tray replacement or could it be a mother board issue not recognizing the fan tray? We have removed and reseated the existing fan tray, the fans are spinning but doesnt look like they are recognized. Earlier the temps were higher, this is in an airconditioned room.
SYSTEM POWER SUPPLY STATUS
Internal Power Supply Type: AC
Internal Power Supply 12V Output Status: Normal
External Redundant Power Supply is absent or powered off
SYSTEM FAN STATUS
Fan Tray: Missing
SYSTEM TEMPERATURE STATUS
Intake Left(Bezel) temperature: 45 Celsius, Abnormal
Intake Left temperature: 48 Celsius, Abnormal
Exhaust Right(Bezel) temperature: 40 Celsius, Normal
Exhaust Right temperature: 38 Celsius, Normal
CPU temperature: 105 Celsius, Normal
Power Supply Unit temperature: 38 Celsius, Normal
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
SYSTEM POWER
Motherboard Components Power consumption = 51.9 W
Total System Power consumption is: 51.9 W
Environmental information last updated 00:00:01 ago
- Labels:
Other Switching
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-11-2013 04:45 PM
Arell1234,
Did you ever sort this issue out? We're experienceing the same thing right now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-12-2013 08:51 AM
This goes back a ways I think that we replaced the Fan assembly. Here is an article that desribes the process
1 | 1 x Cisco 2911 Fan Assembly, 2911-FANASSY | 2911-FANASSY | 0% | $159.95 | $159.95 |
from cables and kits dot com
unless you have support for your routers it would probably be covered.
Hope this helps.
