cisco 2911-k9 CME-SRST License issue
Ramu Ch
Hi Team,
This is regarding customer  Router CME-SRST license activation problem :
https://supportforums.cisco.com/docs/DOC-26706
Based on the above document, enabled license for UC  and CME  and showing that both are as evaluation license.
According the above URL , it will be activated as  RTU (right to use) license after 60days..
Would you Pls confirm , can we get RTU license  after 60days even UC9 is  in evaluation period license because all portals provided the configuration  of CME activation after uc9  permanant license.
I have tried to make uc9 as permanant license , for that we need a  license but to make permanant , we need a PAK,that customer doesn't have/know.
Attached the License details/Sh-tech report/sh version report etc
summary output:
Index 3 Feature: uck9
     Period left: 8  weeks 3  days
     Period Used: 32 minutes 57 seconds
     License Type: EvalRightToUse     License State: Active, In Use
     License Count: Non-Counted
     License Priority: Low
Index 10 Feature: cme-srst      Period left: 8  weeks 3  days
     Period Used: 17 minutes 56 seconds
     License Count: 20/0  (In-use/Violation)
Ramu
paolo bevilacqua
To make the license permament, you need to buy it.
Hi ,
Thanks for the reply..
THough we have a Permanant License , but we got the above status..
Based on the above link, it will renewal after 60days..
Will that happens even in UC9 in  EvalRightToUse state or should it be in Peramanant for
CME gets permanant
Pls clarify
Ramu
