Cisco 2950/2960 memory related questions
Steph1963
Hi Everybody,
Can anybody confirm me that the processor memory shown with show ver command is in fact the DRAM. Also would like to know what is the meaning of 61440K/4088K. Does the 1st number corresponds to the DRAM size, what does the second number refers to?
Also would like to know if the flash-simulated non-volatile configuration memory is in fact the NVRAM.
Cisco 2950
cisco WS-C2950G-24-EI (RC32300) processor (revision L0) with 21013K bytes of memory.
32K bytes of flash-simulated non-volatile configuration memory.
Cisco 2960
cisco WS-C2960-48TC-L (PowerPC405) processor (revision B0) with 61440K/4088K bytes of memory.
64K bytes of flash-simulated non-volatile configuration memory.
Thanks for your help
Stéphane
Reza Sharifi
Stéphane,
To get the total DRAM for your switch, you add the 2 numbers together.  In your case 61440+4088=65528.  So you have 64MB of memory.
<64K bytes of flash-simulated non-volatile configuration memory>
This is NVRAM, and holds you startup config.  Also flash holds the IOS image
Reza
Reza Sharifi
Stéphane,
Reza
