11-02-2004 09:32 PM - edited 03-05-2019 11:18 AM
hi
can anyone explain me difference between switch stacking and clustering
though its very stupid question but i wnna make it clear
11-03-2004 04:58 AM
Stacking is a technology used to connect switches. XLs/2950/3550 support Gigastack while 3750 supports Stackwise technology.
http://www.cisco.com/warp/public/473/150.html
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12114ea1/3750scg/swstack.htm
Clustering is a way to manage certain switches using a web interface
11-03-2004 06:25 PM
hello sir
thanks a lot for ur support i will go through the documents and hope that will clear my doubts if i have any question i again disturb u thanx
01-30-2005 11:53 PM
HI Sukhwinder,
Cisco StackWise stacking creates a 32-Gbps switch interconnection. Stacking does not require user ports. Up to 9 units can be stacked together for a maximum of 468 10/100 ports, 468 10/100/1000 ports, 108 optical aggregation ports, nine 10 Gigabit Ethernet ports, or any mix thereof. It is supported only on 3750 Switch.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_data_sheet09186a0080161371.html
You can make a cluster of different switches like Catalyst® 3550, 2950G, 3500 XL and modular Catalyst 2900 XL Switches to ease their management. That requires a Systems GigaStack Gigabit Interface Converter.
http://www.cisco.com/en/US/products/hw/modules/ps872/products_data_sheet09186a00800a1789.html
